Sam.McAlister
New Member
- UK, Kent
Hello, I have a bit of an issue. At my place of work myself and fellow engineers use a mobile arc welder to do a magnitude of fabricating jobs around the factory. We had noticed that both leads (welding lead & earth lead) were very damaged and were overdue to be replaced. So I was given the task of overhauling this welder and sourcing some new welding leads. I discovered that the outer diameter (conductor & insulation) was 16mm and the inner diameter (just the conductor) was in the range of 9-10mm. I also discovered that the leads need to be rated for 110A of current and 10M long each. I gave this information to out storeman who began chasing our suppliers to see if they had anything in stock. After 2 weeks, nothing. So I have come here to see if anyone knows anywhere I can source these welding leads. Thank you.
