Hi,
I'm currently repairing various holes in the floor of my old Peugeot 205.
The welds I've done so far are quite inconsistent i.e. it seems to spatter/burn through or sit proud on the surface. I'm really after some tips - am I preparing right/using the right settings?
Details:
Clarke 150T welder - power setting 2, low. Wire speed 4
Gas: CO2 pub gas
Welding 0.8mm steel plate to 0.8/0.6mm steel.
Pics of the surface after preparation:
Underneath, it was really awkward to get in with a grinder so I did the best I could with sandpaper
The plate I cut to fit in place - leaving bout 0.5mm gap. Two holes to plug weld to the original seam underneath
Earthing position - attached well enough?
The results - from the top - looks OK but not a lot of penetration
The results from below - you can see the trouble with onconsistency I was getting - some places it has almost burnt through - others there's hardly a mark on the underside
Any tips welcome
Cheers!
Dean
Details:
Gas: CO2 pub gas
Any tips welcome
Cheers!
Dean
. Got any plans for yours? Mine's mainly a trackday/winter hack. I've got a mk1 MX5 for use on the roads in summer but it gets put away for winter as I never want to have to weld it.
