Hi,
The cables I have for Arc are a bit short at only 2m each for ground and rod holder, both 25mm2.
The MIG also included a rod holder, also 2m but only 16mm2. Both welders have 25/10 Dinse sockets.
My gut feeling is to stick with 25mm2 (I think that's max for those plugs). Would that be correct for cheap inverter, supposedly up to 200A, or would 16mm2 be just as good?
Also and related is there any problem using Dinse/Dinse extension lead, reusing one of the existing leads?
I suppose I'm assuming there's not going to be a problem simply from using longer leads. Maximum would be 9m total counting both supply and return.
Cheers
Cheers
