Can any of you guys help with some advice on welding aluminium with a Sip Migmate 130. Aside from the wire snagging up when theres any kind of bend in the tube (followed the guide on here & still got problems snagging unless tubes are straight) I cant seem to get a proper bead of weld laid down. The metal has been prepd & when I start to weld the wire seems to burn back on itself & the weld is frosted looking. It looks similar to when you run out of shielding gas when welding mild steel. I am using a brand new bottle of Argon gas & have checked that the gas is coming through ok.
Any advice would be appreciated.
