oldtel48
Terry
- Essex uk
Can someone give me advice on welding a rust hole in my old range rover classic. At the moment it is about the size of my thumb. I shall be using
.8wire and a 145 amp machine, will I have to grind a v or should I be able to just butt weld it's about 1/6 inch thick
Can I ask as well how I can stop burning a hole at the end of a run
Look forward to hearing from you T Elliott
). also depending where the patch is, make sure there is no wiring routed through the inside of the chassis.
