Hi guys,
I've moved on from burning lumps of aluminium
Current project is trying to weld a frame of 5mm steel rod to hold some plastic containers.
I'm having problems trying to figure out how best to do this - The joints are mostly right angles (two pieces of 5mm round cross-sectoin rod at right angles, ground to 45 degree faces so they butt up nicely). Not having much luck trying to weld them 'freehand' so was wondering if the best way to do it is to tack, rotate the frame, tack, and so on, rather than try to weld it in one go.
I'm sure the problem presently is the arc gap being far too large, as the whole thing ends up glowing red hot, and with a lot of soot!
Any suggestions on current would be welcome as well - I was trying around 30 amps.
Cheers,
David
Cheers,
David
