yorkie_chris
Hello folks,
Have got a bit of a project on with my mates boat.
We want to take 2 loops from the console, up and over back to the A frame.
We reckon 5083 will be most suitable for corrosion resistance, and we can get it, and it should cold form ok because we need to put a bend in it.
Joints to make will be
1 butting the tube against flat plates (at a slight angle, maybe 75 degrees) to make some feet to bolt it down.
2 Teeing two tubes together (tubes are just structure, not holding anything inside)
3 Some plug welds to hold the tubes to some clamps which will slide up inside the tubes.
4 some strips of flat bar maybe 4mmx10 or 15mm butted against the side of the tubing, this will then get drilled to bolt a windscreen and roof cover to.
The tube material is 5083 1.5inch nominal bore schedule 40.
The stuff for (1) will probably be 4mm plate, I'd like to use as thick as possible in the hope that it will stay flat but on the other hand thicker will need more heat.
Any recommendations on this score?
What filler wire should I use?
I've got a 200A AC chinese TIG set, is this going to have enough poke or am I better off prepping and tacking everything and taking it somewhere to have it done by someone with a bigger machine?
And last of all if it's not too cheeky, does anyone deal with this material and could I have some offcuts/scraps to have a practice on before we spend the cash on ordering the full lot?
Many Thanks
Chris
Many Thanks
Chris
