Afternoon Guys,
Bit newbie to welding and first time posting so please go easy!
After a bit of advice if possible please.
I need to weld some 10mm plate together and im not sure if the equipment i have access to will do the job.
Im wanting to weld some 10mm plate together to make a security clamp to go around a motorcycle wheel. I have access to a Cebora Auto Star Mig 180, and also a 200 amp budget DC Inverter arc welder. With the arc welder i have some 6013 3.2 and 4mm rods.
Will either of these setups be sufficient to weld the 10mm mild steel? i would rather use the mig if possible.
I have a 16amp power supply to use both machines on.
Thanks in Advanced.
Jamie.
Thanks in Advanced.
Jamie.
