I've taking the advice of some on this forum and decided on a Clarke mig welder. I just can't decide between two models, basically because the specs are a little confusing (little in it price wise).
The 175TE has 175 max amps with an 85A duty cycle (60%) and welds up to 6mm thickness (quoted)
the 205TE gas 205 max amps but a lower duty cycle of 80A but can weld 1mm thicker (7mm)
Detailed specs are here:
http://www.machinemart.co.uk/rangeguides.asp?t=068&g=105&r=2031%>
I'm assuming (please correct me if I'm wrong) that while the 175 would be better for constant use the 205 would be better for short bursts of use and would be able to weld thicker material??
