hotponyshoes
- Somerset. Uk
I am just having some initial thoughts on making up a jig for butt welding 2 pieces of tube together.
My first idea is to fit 2 ball bearings into a vee bracket. Make 4 of these up and fix them to a length of box section.
Add a torch holder/positioner and then I can lay the tubes onto the bearings and rotate it under the torch.
First question- can I use the bearings as the return path for the welding current?
Ie. Just put my earth clamp onto the frame?
Initial section is going to be 25mmx1mm 304 tube but I would like to build it to handle bigger tubes and may want to use some ac for alloy.
Was thinking of using stainless bearings but only because it will be stored in a damp workshop.
Also thought, as it's low speed imay be able to get away without greasing the bearings which may or may not be better if i am using them as a earth path?
Will this work or will I get arching across the balls in the bearings?
