Hello. I have just joined and this is my first post here.
A friend gave me a Clarke 100E Mk2 MIG Welder. It was a bit battered but it has cleaned up nicely and seems to function nicely.....up to a point.
I have been practicing my skills, or lack of them, on some scraps and am finding that after a very short period, the welder stops functioning and just makes a clicking noise when I pull the trigger. I have to leave the set for about 30 mins before it will function again.
I am welding 25mm mild steel box section with a wall thickness 2mm. I am using 0.6mm wire and I can probably do one run of 25mm weld and about 10mm on the other side before it cuts out. Everything is set as it should be according to the manual and the welds it does produce are acceptable.
Has anyone any ideas why it should cut out so frequently? I don't think 35mm of weld on 2mm thick mild steel is an excessive amount of work. I have cleaned the electrics with an airline so all is clean in there and nothing is likely to cause a cooling airflow blockage.
I am wondering if there is a faulty component and if so, which component it is likely to be.
Any help suggestions would be very much appreciated.
Regards
Tom
Regards
Tom
