Will your Portamig get into spray transfer using 0.6mm wire?
not sure what you mean Gordon.
I'm currently using .08 wire.
may try the .06 once I've run out of .08.
been having problems with this spatter lark.
I've had the setting on fine no 6..course 1, wire speed around 5.5 to 6.
spatter not to bad but could do with amp going up a bit.
tried fine 0 course 2 wire speed around 6 to 6.5
way to much spatter.
maybe the problem is I'm welding 6mm or 8mm solid round onto 1.5mm wall tubing??.
also the wire feed isn't to bright either..if there's a slight kink in the torch cable(burn back).
keep it straight'sh its OK.I've tightened the knob but not tight enough .
checked to see if I've got it in the right grove and it is.
on it maximum tightness I can stop the wire from coming out,whether that's normal for this welder?(portamig 215)
took it apart and blow through the torch with a air line,put a new tip on seems to improve it.but still not quite right.
also I need a new shroud, not sure what size I need so I will have to check my torch.
also maybe I've not got enough gas going through?
I've set it low enough to give a good weld on a flat surface.
so with welding tubing maybe its need turn up a bit?
