James Braithwaite
New Member
- Cape Town South Africa
Hi there,
I'm a bit stuck specifying a weld size (bead throat) for a design I'm working on.
The pieces to be welded are 2mm thick 6082 extrusions.
Strength calculations I've done indicate that a 1mm throat would suffice (using 5356 filler), however I have no idea what a reasonable minimum weld size is.
I have been taught that the size should be between approx. 0.6 and 0.8 times the material thickness.
I've seen a couple of examples of 2mm aluminium welded with quite thick welds, so it seems it is possible to exceed the 0.8*t rule of thumb without burning a hole in the extrusions...
I'm suggesting TIG welds as it seems to be the preferred method of welding thin aluminium (less heat penetration than MIG).
My questions are:
1) What is the minimum weld size (bead throat) that is achievable with TIG?
2) Is it safe to exceed the rule of thumb I mentioned above?
Thanks
James
My questions are:
Thanks
James
