Just some background regarding a joint our shop uses often.
They mig weld 1/2" TP100 to an 8' steel ring (C1030, Q&T to 90ksi) at approx. 20 equally spaced points with two oval welds at each point. The steel ring is 3.5" thick and is preheated to 150 deg. F. The 1/2" TP100 is not preheated. The shop uses the ER-110 metal core wire. The TP100 is similar to ASTM A514 and has a minimum yield of 100ksi but with a maximum of .1% carbon.
I am experiencing cracks after the unit has been in service and also had some failure analysis done and found the cracks to originate in the HAZ of the weld.
I am not directly involved with the shop procedures but think the shop should be preheating to a higher temperature - 400 deg. F and using a filler wire to match the lower strength material such as a 7018 or 8018 type wire.
Comments?
Comments?
