Stueeee
Old git
- N W Kent
Several years ago I needed to weld a 10mm diameter rod which lives in the firebox of my oil fired kitchen range. This component probably runs at or somewhere near dull red heat when the cooker is running. The rod material is steel, but is quite hard, can be sawn but doesn't feel like a mild steel.
At the time I needed to modify this component it already had a welded joint. I cut through the original weld and MIG welded it back together in the different position I needed. The problem is, about every 12-18 months this weld fails and needs to be redone, which is a pain as it always fails at the most inconvenient time. My MIG weld deposit has pretty much disappeared when this failure occurs.
My question is, what rod could I use that would have the kind of hot strength/endurance needed here. I have TIG, ARC and OA kit here as well as the MIG.
PS. Apologies as I know this isn't necessarily a TIG related question but couldn't find anywhere anywhere where it seemed to exactly fit.
Thanks, Stuart.
Thanks, Stuart.
