Hello everyone,
I am new to the forums and new to welding and i have been practicing alot over the past couple weeks. Been alot of fun so far.
Anyways, my welder is the Hobart 187. It is a 220v welder and is rated at 185 amps. It has power settings from 1 to 7 and wire feed settings from 1 to 100.
My question is.. Does the weld in the picture have good penetration? Its a cross section that i cut off.. I'm mostly concerned with the under portion circled in red. The thinner metal on the bottom is 1/8" steel and the thicker one is 1/4". I used power setting of 5 and wire feed setting of 45.
Basically you can see a crack (circled in red) along the bottom portion between the metals. When welding a 90 degree angle, am i suppose to penetrate that far? Any tips or help would be greatly appreciated.
