Everything moves and works smoothly.I'd be checking the lock is securely fastened in the door, and the handle mech is working well enough to allow everything to be in the right position for the key to rotate fully to unlocked - the door mech (not the lock) may just need lubricating to allow it to move freely. I can't get the key out of mine if the handle isn't fully in locked or unlocked position for the door mech.
Removing the lock from the door and testing it on it's own should indicate if its the actual lock if that fails.
UPVc door at my tenants house.
Can only remove the key when the door is locked!
When I was looking at it the tenant had to pass me the key through the letterbox so I could try from outside. Same again.
Any ideas anyone?
yep ,,, take the old one to get the length the same ,,,So it is only the lock barrel needs changing then not the door locking mechanism?
Whatever happened to "lock bumping"?Late thought - if you buy a new lock go for an "anti-snap" type. Google explains![]()
