skotl
- Edinburgh, UK
Having fun today, turning a sump guard into a reindeer (don't ask...)
The sump guard had some foam insulation and I did try to remove it but quickly realised that it was a futile task as some foam would always be left behind.
Happily welded away and the odd mini-fire was put out just by blowing on it.
One set of flames wasn't listening to reason, though, so I figured that discretion should be the better part of valour and I blasted it* with my powder extinguisher. It was just a half-second blast, but I watched in horror as the gauge wound all the way round to empty, even though the trigger was off.
Is this normal? Does even a short blast empty the extinguisher?
Suppose I need to get it refilled, now
(* there was never any danger - the reindeer was either on the welding bench or on the concrete floor - if I hadn't used the extinguisher I could have easily carried it outside and let it fizzle on the grass)
), get another as well if you can afford to, so you have back up if one is off the road-but also to place opposite t'other one in case the fire is tween you and where the xtingy thing lives.
