pondy
- chedburgh, suffolk. uk
a friend of mine drives a 96 hyundia accent, its done 122k and its going rusty, it has got a hole in the rear ache which im going to sort, never done any welding to body work but after much reading im sure i will do ok.
the floor pan has alot of what i would call surface rust at the rear, there is no holes and no large flaking parts, its been adviced on MOT. ive been asked if i can treat this to get some more years out of the car, is this just a case of removing what i can with a wire brush on an angle grinder than going over with a thick coat of waxoyl or is there anything better to use?
needs to be on a budjet as the car isnt worth much and ive just charged him £600 for fitting a new clutch, exhaust and lower arm.
on another note 10 months ago i cut some rust out my own car, welded in 11 patches so all the rust was gone, then i painted over any bar metal or wire brushed rust areas with hammerite (might have been a bad idea). then did 2 thick coats of waxoyl (hammerite brand). check is recently and its holding up but around the welds there is some little air bubbles were its started the rust, should i wire brush these and then re waxoyl? also stone chipped the sills but this is chipping off and rusting again
