What's the best way to get rid of water once it's got into a petrol tank?
This was from the fuel tank from our inflatable, which doesn't get much use, doesn't even get topped up some years. I couldn't say when it was last actually emptied.
Anyway I tipped a couple of litres from the outboard tank into the chipper, with no problems. The rest went into the ride on mower, which is where the water showed up when it died after a couple of minutes. After finding water in the carb, running off samples from the tank until it appeared clear, I ended up having to drain the tank right empty, tipping the mower up to make sure. A bit of fresh petrol and it fired up and seemed to run perfectly well although I only tested for a few minutes.
Next day it died within a few seconds of starting. Water in the carb again. Not just that but a sample drawn from the tank had more water than petrol. I've drained the tank again, and with fresh petrol (again) it seemed OK at least for a brief test.
So the question is still, what's the best way to make sure all water is truly gone, and not sitting in drops or a film or something waiting to suddenly drop to the bottom? As well as the mower I need to deal with the outboard tank, which I can leave open for a few months to dry on its own. And the chipper is suspect as well, since it had some of the dodgy fuel.
i wont use the stuff on my norton bike generator and garden gear
