citizen kane
After some advice about water cooler flow rates.
I've recently purchased a second hand water cooler from a well known welding supply company in the west country. The water cooler was sold as working but noisy. The quoted flow and pressure for the pump was 4 bar at 40 l/min. The cooler is also offered with a flow switch that can be interlocked to the torch or foot pedal switch to prevent the welder turning on if the flow is below 1.2 l/min.
At the same time I also purchased from them a Weldcraft WP20 torch, when I plugged it all in I could only get a max flow of 0.9l/min pumping into no head.
I've since spoken to the company about my concerns but they are are of the opinion that this flow rate should be OK and have suggested that I give it a go and see what happens and check the torch head dosnt get to hot
OK, my main concerns are not the torch head but the power cable/water feed line, I assume this will be the fist thing to die if the flow it to low.
Anyone any experiance with this that can help reassure me that I wont fry my new torch.
