Evening,
Had the washing machine trip the RCD the other day and am trying to troubleshoot the cause as I’d rather fix than replace if possible given it’s less than 4 years old.
Originally would power up without a fault but when you start a cycle the door mechanism would lock and it would trip the breaker. I recently wired up a new supply to the shed so thought I’d cocked something up in the process. Checked the supply, no apparent issues, then plugged the machine in to another socket (upstairs via an extension lead) which is off the other RCD on the consumer unit and tripped that too. So pretty sure it’s the machine at fault.
As it was tripping when the cycle went to start I disconnected the interlock switch and powered the machine back up. Power would come on without tripping the board so I thought it must be the interlock switch. However I tried to hit the start button and it tripped the breaker again. Now what I’m unsure of is with the interlock switch disconnected would this cause the RCD to trip or is this likely pointing at something else? I do hear the switch click when it is connected suggesting that it is functioning?
From reading online I understand that when the cycle starts there’s a number of items energised (interlock, motor, heater etc) so thought if the switch is activating it could be something else. Going to pick up a multimeter tomorrow and check resistance across each of the components but not sure what values I should be looking for, any hints?
As you’d guess I’m a novice at this sort of game so any advice is welcomed.
Cheers
Kane
Cheers
Kane
