I reckon someone here might know this one...
The walls in my bungalow in Bedfordshire are of a construction I haven't come across before. There is a single outer skin of red brick. Inside this (with a narrow cavity) the internal walls (including dividing walls between rooms) are made of large plaster slabs which are about 3" thick, the full height of the room (about 8ft) and about 2-3 ft wide (I can't be exact since I'm not living there at the moment).
The slabs (or blocks?) are hollow, with about 0.75" thick faces and internally a plaster honeycomb with each cell measuring about 6-8" across.
The house was built in 1957, hence I think imperial measurements are more appropriate.
When I bought the house some years ago, the survey described the internal walls as being of "hollow concrete block" construction but once I started working on the house I realised that this wasn't the case.
Has anyone got any idea what this construction is called so I can find out more about it? And more to the point, so I can perhaps enlighten any surveyors who come to survey the house on behalf of prospective buyers?
