gerry hattrick
,morning
ollowing a thread in the forum re seam sealers led me to Frost Auto Restorers website - http://www.frost.co.uk/default.asp.
Their Product code W160 lists a Spot Welding Unit that is powered by a MMA welder and the claim that it is possible to spot weld from one side only.
Does anyone have any experience of this device?
Using a MIG to produce button (plug) weld has on two occasions needed me to extinguish a small fire inside a cavity because Waxoyl or some other rust retardent had been used at some earlier time. In one instance I had to drill a hole to allow a water jet into the space. In the other case a hole was already available.
I wonder
if the 'spot welder' described might allow welding without sufficient heat build up to ignite any combustibles in the area.
Dave Ball (gerry hattrick):
Any comments?
I wonder
if the 'spot welder' described might allow welding without sufficient heat build up to ignite any combustibles in the area.Dave Ball (gerry hattrick):
Any comments?
