do they do other colours?Mipatherm. I get it on eBay and it comes from Germany on 48 hour DHL. Tried the others, that’s the only one I’ll use for our products now
https://www.ebay.co.uk/itm/282706232603
Dunno!do they do other colours?
From the air in the blasting setup if it’s not dry I would of though.
most of the time the moisture you’re seeing from a blow torch is the combustion creating CO2 + Water
i use the diesel comp 1st thing is couple all the gear together start the comp and open the reg tap on the pot with the grit valve turned off and the blast hose well secured after 5 minutes the air gets hot and the moisture travels down the pipe and blasts out of the water separator then all dries up and off you go. you can carry on all day with no problems as long as its hotInteresting preparation. We're going to blast this one, where would the moisture come from?
