Hi All
Finally switched welder on for the first time and had a go and wanted to report findings and kindly ask for any advice.
Settings as follows;
Gasless with 0.9mm wire
Feed - started at 6 but then went down to 5
Switches - A/3/Min
Material - 2mm mild steel
Upgraded Earth Clamp
I started with simply running torch down a piece of the steel to see if I was getting penetration. Then I tried to spot weld a small piece of 2mm onto a larger piece.
the first thing I noticed was splatter, and I mean A LOT of splatter! It was shooting all over the place.
I also found that the welding was inconsistent eg one weld would be better than another even though I thought I was doing it the same way.
Here is a couple of pics of my attempts (top and underside).
Any comments and tips helpful
Switches - A/3/Min
