side-show-bob
Side-show-bob
- West Yorkshire
I am going to be sending my first gate off to the galvanisers shortly and have been reading about venting. i am still alittle unsure as to where to drill the vents
The gate is 2 meters tall and 1.5 meters wide, it is constructed from 40mm box frame and them has 7 bow top rails in the middle. there will be 3 evenly spaced 18mm holes down one side (for the eye bolts)and the frame will be mitred so it will not have any dead ends in the frame. It has a slide lock running through the centre of the 40mm box with a frame to house the other end, i have drilled a 30mm hole in both ends where it meets the frame to allow the galv to flow through it and cooat the inside.
Its like the one bellow but mine runs through the centre of the box not on the outer edge.
[/IMG]
will i have to drill any more holes in it or will the eye bolt holes be enought.
Thanks
Rob
Thanks
Rob
