RonA
specialist in repairing sealed for life equipment
- Stockton on Tees, UK
Anybody had any experience with these?. My son in law had two tyres changed on his 2010 car & the tyre fitter was unable to get the tyre valve cores to seal while trying to re inflate the new tyres. The fitter had to resort to fitting standard tyre valves & removing the combined tyre valve/pressure sensor. The valve/ sensor although carrying a Vauxhall marking is actually made by Schrader.
A repair kit is available comprising new valve stem to wheel aperture seals & locking tube nut, additionally a new valve core is also supplied.
However, despite using the correct valve core removal tool have only succeeded in breaking off the top of the valve core & leaving the core body firmly stuck. So far I have tried hammering small file tang into core but it stubbornly refuses to budge. It should be noted the valve stem is alloy & I suspect some form of electrochemical corrosion has taken place.
The problem is replacement valve/pressure sensor modules are approx £75 a corner & if the two rear wheels have the same problem, a bill of £300+ looms ominously.
The only saving grace is that on a 2010 car, it wouldn't be an MOT failure only an advisory, not so with later cars
RonA
RonA
