Hi everyone,
Been lurking a while, but have recently acquired a BOC 180P with a CO2 bottle, and a very generous pile of scrap flats to stick together.
Have just been running lap and butt joints to get the settings tuned, and think I have a few things figured out.
-I had cases where (using the settings from the sheet) it would splutter as I was running, even though my stickout was quite tight (I was bumping the nozzle into the pool quite often). I turned the voltage up 1-2V above recommended, and that seemed to help. Is this because I'm using CO2 rather than the recommended argoshield? I was planning on getting a rented bottle once I had something more than scrap to weld.
-What happens with too much voltage? (aside from too much heat input)
-Low inductance causes lots of splatter and a rough weld, too high inductance causes ???
-Just because the metal isn't glowing, doesn't mean it isn't hot!
I can post pictures if you like.
Thanks in advance.
Thanks in advance.
