Maker
Most folk just call me; Orange Joe
- Keeler crater
Rectified DC is a 100Hz pulse, it makes you shake, DAMHIKTDc is more dangerous as there is no pulse as with AC, so once you get hold you can't let go.
.. one might venture that a viable alternative would be a clear perspex box as the trap and the doorswitch actuates a gas valve (like you'd find in a MIG welder, for example) connected to a bottle of a suitable asphyxiant gas... Argon, let's say
Set it up to deliver just enough flow and pressure to purge the box; five or ten minutes sniffing that should do for most mammals, I would have thought.
... you don't want to have Argon leaking into the house and find youself waking up dead.Good idea, hook an ignition coil up to the rat trap.ignition coils
.I have had an ac shock and can tell you my muscles wont react quick enough to a 50hz supply (50 times a second).![]()
They weren't impressed, lost an entire morning's work on their computers.I've had vermin problems myself in the loft and as I don't really like poison or clearing up from a heavy snap trap, I bought a thing called a 'Raticator'. Runs off 4 duracell batteries and they basically wander into the thing and step on two plates. I suspect the voltage is quite high (several thousand volts I suspect due to the arcing if there is any contamination). As above it doesn't take much current to kill them but the volts helps to get it through them. Killed about 35 last year on same set of batteries, put the bodies on the lawn and within the hour the red kites had taken them. None this year as I think I managed to find where they were coming in and blocked it up. Had a CCTV rigged up in loft so I could see the trap from my computer.
