CompoSimmonite
- Werrington, Staffordshire Moorlands.
Many years ago I made the mistake of replacing the leaking non asbestos flat roofing sheets on my concrete garage with metal sheeting. Obviously big mistake as terrible condensation so need to do something to correct the problem. Initially I considered lifting the sheets just enough to add a layer of ply covered with waterproof membrane but that has progressed to now changing the whole roof for an apex with insulated tile profile sheets. The current roof trusses are made out of 1" x 1/8" angle that are welded into a flat box frame that are suffering from surface rust so need a lot of work to clean up.
I'm thinking, if changing to apex, of using galvanised Unistrut to make new trusses.
Anyone think of a reason why Unistrut with bolt together joints using standard Unistrut brackets won't work or isn't a good idea ?
Thanks.
Paul H.
Thanks.
Paul H.
