gasket999
getting there...
- Manchester, UK
Second query of the day.
I need some 8.8 or 10.9 bolts that won't rust. Unfortunately A4-80 stainless won't do.
Some of them are going into existing mild-steel captive nuts - so while galvanised bolts would be other wise ideal, in this case they won't work as, in the UK, they're standard sized bolts that are then coated with zinc. Its the nuts that are tapped oversize to allow for the zinc on the bolt threads.
However, I understand that in Europe, the reverse is true - the bolts are cut undersized to allow for the zinc thickness.
Does anyone know where I could buy a small quantity of true-to-size/Euro-spec galvanised bolts? (M10, M12 and M16)
