JonnyAlpha
Sorry this has been asked by me and others on several threads but on looking back I just need some clarification:
I have cleaned up the underside of my Mini Restoration to bare metal as I have been working on the project and to prevent any rust it has one coat of Epoxy Primer (Joton Jotamastic 87) this was applied with a mix of a brush and mini roller.
I am running low on Joton and originally was going to apply two coats before Seam Sealing or is this overkill, if I don't will the following plan be OK:
1. Epoxy Primer
2. Seam Seal
3. Gravitex
4. Cellulose Top Coat
I have read that the Gravitex can react with the Seam Sealer so I was going to do another coat of Epoxy but as I am low I do have some Cellulose Primer which I could spray after Seam Sealing and before the Gravitex.
I was also going to put a coat of Epoxy after the Seam Sealer but in response to another thread was told its not required?
After step 4 does anyone recommend anything else (I have seen suggestions of using Waxoyl)
Thanks
1. Epoxy Primer
2. Seam Seal
3. Gravitex
Thanks
