'lo all,
I'm after a pair of U-bolts for a project but they appear to be an odd size as I seem to be drawing a blank at all my usual suspect suppliers (not that I have an extensive list). The existing bolts are 5/16" and clamping a 1 1/2" diameter steering rack but they only stick through the mounting plate by a few threads which I'm just not happy with. There's obviously no issue with changing to M8 and I've got a bit of wiggle room on the width too so 40mm-ish internal should be no problems.
The only suppliers I've found seem to do bolts that are for a slightly bigger diameter which I could probably accomodate but they are M10 which I can't accomodate or the next size down won't fit around the rack and are only M6. Exhaust clamps are available ad-infinitum but apart from the strength issue they aren't any longer than the existing bolts anyway.
Any idea where I might find high tensile extended leg U-bolts? Ideally in Lancs or someone that will do mail-order if possible.
Thanks
Iain
Thanks
Iain
