I have turbo 150 thing. Came to use it today and not wire feed. Press the trigger and there is no movement on the relay or motor drive.
Took the top off the relay and if you press the top the wire drive runs and the welder welds.
I have checked the switch on the torch and this is working fine so there is something amiss on the PCB.
If i do this transformer mod will this sort the problem out as there appears to be no voltage going to the coil of the relay ??
the relay looks fine just lack of power going to it.Pursume that square black thing on the board is the power supply for the relay ?
