I run a Harley Davidson – I like it – I’m not suggesting everybody else should.
It runs spoked wheels and therefore runs tires with inner tubes. (Do not confuse these with BMW wheels, which equally can be spoked, but in an unconventional pattern, thereby allowing them to run tubeless tires.)
Anybody who has worked on a Harley will appreciate that to remove a front or back wheel you’d better be in a workshop with lifting equipment and even then the process is a pita, and this you would have to do with a puncture in a tubed tire.
So…. as I want to travel further away from home I considered modifying my rims to enable me to run tubeless tires and with a tubeless tire repair kit, complete with 16/25g CO2 cartridges, I would not render myself stranded in the event of a puncture.
BUT…..
What happens if you have a puncture with a tubeless tire and the “bead” of the tire detaches itself from the rim? Does the CO2 cartridge supply a sufficient volume of air to re-seat the tire?
It would seem that tubes are the preferred option – but only if being able to remove the wheel at the side of the road is an option – which for me, it most certainly isn’t.
What is the “go to” opinion on this? What is everyone doing who is travelling further than “just down the road” ??
BUT…..
