Hi Everybody,
I know there are some knowledgeable people on here after reading previous posts but I haven't managed to find the answers i'm looking for!
I have a 3 phase screw type car ramp. A 4kw High torque static converter. and a 6Kw single phase generator.
We have hooked it all up but the voltage reading on the output gauge of the converter is only 140ish volts. When we manually open the throttle on the generator the voltage indicated on the converter is 400v.
When we try and operate the ramp without opening the throttle on the generator we can feel the machine vibrating through the control panel.
We thought at first the generator was the issue, tried hooking it up to single phase mains supply and the output reading was slightly lower at 120ish Volts.
Any ideas why the output voltage from the converter seems to be lower than it should be? I'm assuming it should be reading 400/415 as when we open the throttle on the genny we can get the motor to move but it chatters like f*ck!! Tried swapping 2 of the phases and same thing. So now i'm stumped - Seems like i have a selection of issues and I don't know where to start! Short of getting a spark in to have a look!
Any help/advice would be much appreciated!
