Bill Edwards
- Scarborough, North Yorkshire
As to LED bulbs, they may offer some improvement over regular bulbs but quite often the issues tend to be poor/weak/corroded connections to the bulbs.
So I try to use LED light units wherever possible, fit and forget about blown bulbs and rusty connections. Maypole stuff works, some cheap stuff doesn't.
These do the job: https://www.ebay.co.uk/itm/x2-LED-T...=162473113946ca5716d25d4b40dca63a2ff7cab84172
Something to bear in mind though with LED's is that you should add a ballast resistor for the indicators, otherwise the vehicle won't know they are connected and you don't get the beep/warning signal to remind you that there's a trailer attached.
