It's best if you can get 2 axles on there - helps on the stability side of things. Most of the homemade ones I've seen used the Aframe and the axles from a caravan trailer but the rest was homemade.
There are regs. about trailer that I'm sure someones got the link for. Certain things you can/can't do
ISTR Twin axle trailers have to have independent braking.
Personally if I was to build another trailer (my first was an ex caravan) I wouldn't bother. You'll spend more time modifying it. Get hold of a back axle out of a Berlingo and build one from there.
I used to work for a coach builders have have spent a fair bit of time under them modifying the rear axle assy. Very simple and easy to mod
There are a few. Also, you can find stiffer torsion bars in some estate 405/Xantias. Go to a scrappy with your vernier calipers! Last time I did that I was given a proper dodgy look from the scrap man
It's easy to adjust the tension on the torsion bars. It was one of the jobs I did. As you say loads of different cars have them. So you are not limited to Bingo's lol
How do you adjust the tension? I know the height adjustment etc, I'm about to rebuild a rear beam on my car. But for uprated torsion bars youre looking for £3/400 each, and you need a pair!
forget the berlingo axle, building trailers with car/van brakes is illegal.
I carried an autograss Nova - I'd imagine similar weights - on a 1300kg alko caravan chassis and it was the smoothest trailer I've towed.
They're stronger than people give them credit for, and an alko chassis is a trailer chassis, purchased by the caravan builder to put their body on. Providing you meet the lighting/mud guards/tyres etc regs, then all you are doing is modifying an existing trailer.
As mentioned above, forget the car / van axle option unless you will be under a gross trailer weight of 750kg. Above that (up to ~3500kg) you need overrun brakes. A decent caravan chassis is a reasonable place to start from, but unless you can find one cheap the finished trailer may well cost as much as buying a purpose-built job secondhand.
Hi Peter,
The problem is getting the overrun brakes to be auto-reverse - that requires special gubbins in the brake drum which a car or van doesn't have.
Older trailers didn't need to have that facility of course
