Lawnmowerboy
hi all, i hve recently been given a 6x4 trailer by a freind in return for some work to his fergie tractor over its pretty rusty but quite solid i am using the original axles but have done the wheel bearings and tyres as there mini wheels
the hitch coupling is a good ol' Bradley cast one but i intend on completely rebuilding it using the old body as a pattern
first i intend on making an a frametype thing made from 2mm 40x40mm box to carry the hitch running all the way under the trailer then again using the same metal toconstruct a 6x4 rectangle with a few crossmembers then weldthe a frame to the bottom of that then fabricate the sides 1ft high all from the same guage material then plywood the base in 12 mm and the sided in like 8mm
any thoughts
will
any thoughts
will
