ok good job found a cheaper alternative just has the covering on it. not sure if phenolic ply is that colour the while way through likely stronger?
here is the covered stuff. the trailer has pretty close spacing of steel braces underneath so don't thing strength will be an issue.
http://simeonbateman.co.uk/catalogue/sheet-material/ply-wood--mesh-faced/
and yea only just started using those self drilling screws they are the J O B!
now were to get cheap (decent) jockey wheels??
That looks like the right stuff. The brown colour doesn't go all the way through. although the edges are often painted brown on full sheets. On a similar note it's often worth sealing any cut edges with some sort of waterproof paint for the best possible weather resistance.
good stuff chaps these trailers might be worth fixing now!
just need to find some cheap jockey wheels?
any ideas?
£17.89 + vat
http://www.northerntooluk.com/trail...hsearchterm=cheap+jockey+wheels&search=SEARCH
or ebay
http://www.ebay.co.uk/itm/34mm-Jock...ailers_Transporters_Parts&hash=item337341fe0b
£11.25 + £6.00 delivery
