Half way through my fold flat trailer build , but been hampered with the bad weather , cannot get it out in the yard to spray because of the rain where getting here in the North . Still a bit welding to do though . I thought I'd ask for some advice regarding the position of the trailer frame onto the torsion axle . I thought the weight would be on the axle itself , but a mate said the weight should be balanced over the hubs .What are your thoughts on this ?
I've put up a few photos so you get the idea:
This last photo, you can see the stripped line of the center of the trailer .The distance from axle
to hub shaft is 6" .Should the trailer middle be over the wheel hub or the torsion box section ?
Or rather , should the weight of the trailer be over the wheels or the torsion section ?
I do know there has to be a certain weight on the draw bar , so it cannot be balanced perfectly .
I would appreciate some advice on this .Thanks
