peterd51
happy to be here!
Hi Guys,
In between moving the workshop around and setting up my lathe I've been looking at a home made bottle trolley that I was given some time ago.
I don't need one as my Mig has wheels but what I did need was something to transport my tool box as it's pretty heavy and I'm getting a bit old to be dragging it up and down the drive!
It would need some kind of vertical angle iron in each corner to stop the toolbox falling off as I trundled around but it would also need to allow access to the bottom drawer without lifting the toolbox off.
I wanted it to be able to carry the socket set and allow both box lids to be lifted to get at the tools and sockets. It would also need to go directly into my lock-up tool cabinet, so I spent a day or so thinking about it, came up with a workable design and set to work.
First I cut up the old trolley to get some usable metal and the wheels, handle, etc, then cut some 1" box to make the base frame, see photo trolley 2. I cut some box and drilled holes in each piece then cut some rod to make the legs for the wheels, see photo trolley 4.
trolley2
trolley4
I added a couple more slightly longer box sections to the rear end, these take into account the wheel radius so the bottom frame is level, see photo trolley 7.
trolley7
After making a handle I welded it on with a door 'padlock' clasp, see photo trolley 9. At this point I realised that it would be nicer if the handle turned at an angle a bit less than 90 degrees so it would be almost parallel to the ground as I moved the trolley.
trolley9
But then I'd not be able to shut the tool cabinet door, so I made the top part of the handle detachable, see photo trolley 13.
To hold the socket set on top of the toolbox without it sliding off when I moved it and allowing for the fact that the two boxes are different sizes, I decided on two rectangles made from angle, welded together back to back. see photo trolley 12.
trolley12
Finally I painted both sections and added the wheels, see photos trolley 13 & 14.
trolley13
trolley14
Now I can easily move the tools to the car I'm working on, generally at the bottom end of the drive, lift off the top carrier and open up both tool boxes.
Regards
Peter
trolley2
trolley4
trolley7
trolley9
trolley12
trolley13
trolley14
Regards
Peter
