Are you ordering Hot Rolled ?I don't know if this is a daft question or not. When I order mild steel it often appears with a kind of black coating or oily surface. What's the best way to remove this for painting?(Particulary for larger items)
Pictures or it never happenedI've been using a flap disc to weld
You CAN weld through it, once you get a spark going, but its not best practice. The weld will not be as neat, and will not be as strong as it could be.Now that I think about it, that explains a lot. I've been using the welder to clean off the mill scale. Maybe I've had things back to front.![]()
Mill scale. You will need to remove it to weld, and paint does not adhere well to it either.
