I’ve just done this,but did wonder about thick gear oil like 140 warmed up,it’s probably cheaper.
Waxoyl shutz on the exterior and Dinitrol on the interior of cill repairs is my go to.dinitrol cavity wax would be my goto.
after the paintwork.
Now there’s a pleasant odour!Worst money saving idea ever! Have you smelled gear oil?
^^^^ Very true, when i restored my Moggy pickup around 1990-1 It had a lot of new panels, chassis legs, sills, floorpan etc. All waxoyled.Not wax oil. Goes hard and flakes off. You're going to weld it twice with waxoil, second time will have more flames.
Dynax s50.
None of the aftermarket spray waxes are a permanent solution - all need regularly reapplication - their very selling point of creeping into all the crevices is the reason they start to fail as the layer thins out over time. Reapply ever few years and they all seem to be reasonably good.^^^^ Very true, when i restored my Moggy pickup around 1990-1 It had a lot of new panels, chassis legs, sills, floorpan etc. All waxoyled.
Halfway through doing much of it again. In places it didnt even look as if it had ever been on there.
What i need is a drum of Cosmoline!
+1 for Dinitrol (or other cavity wax) ....do it on a nice hot day and keep it topped up.dinitrol cavity wax would be my goto.
Never ever seen waxoyl go hard and flake and fall off, unless the rust layer falls off from under it. Which may indicate a problem with the waxoyl - not fully wetting the rust? Which is why I mix it with oil, whatever I have lying around really.^^^^ Very true, when i restored my Moggy pickup around 1990-1 It had a lot of new panels, chassis legs, sills, floorpan etc. All waxoyled.
Can become a nice fire inside cavities to, but easily put out.As said, at the end of the job. However. The jury is out. If it's brand new clean sections, it's good stuff but if the section has corrosion especially post welding corrosion that has not been cleaned, it will trap the water underneath and actually promote the corrosion. In the words of Mr H Callaghan. "Do you feel lucky?" As a BTW, I once did a weld repair to a chassis section that unbeknownst had been treated with waxoil. It obviously boiled it and it ran down the chassis and on to my overalls. I hadn't realised until I felt the burning. I still bear the scars 20 years on.
Nick
i mix it with oil too , so it gives the oil enough body to hang on but not set hardNever ever seen waxoyl go hard and flake and fall off, unless the rust layer falls off from under it. Which may indicate a problem with the waxoyl - not fully wetting the rust? Which is why I mix it with oil, whatever I have lying around really.
