allstar_07
I has originally posted in the specific machine section but probably better in here...
(I borrowed a T130p usong gasless 0.8mm wire)
I had a little practice with the gasless wire and thought it was going ok so had a go on the car which happened to be a section of the sill (10cmx5cm). I'd decided to cut the shape out to fit the hole and therefore have a butt joint...in hindsight I probably should have put a patch on from the inside and then just filled it rather than trying to be clever.
Anyway with the power setting on low-high (T130p) and wire speed set to roughly the 9pm poistion i managed to tack it in place and then actualy weld along the top join quite well using the curved zig-zag motion. However when it came to the sides which didn't quite join up so tightly (i.e. 1mm gap say) I ended up just blowing a couple of holes in it (presumably due to the edge being exposed?). I turned the power down to low-med and the wire speed to slowest. This just seemed really underpowered and just spat lumps everywhere. There doesn't seem to be a middle ground so not sure what I could actually do to make it better?! What do people do when theres a gap in the join? Also is there a remedy for filling in the small whole, in the end i used the med power setting untill i got enough crap on there to fill it - but far from ideal!
Should i just stick to overlaps?!
Cheers
edit...I've been reading the tutorials again and its still unclear to me how to weld the lap joint. I understand you angle the tip towards the edge of the top piece as in the picture in the tips section but would you just run along the join or use a zig-zag over the two pieces?
Cheers
