I struggling at the moment keeping my torch in contact tips. Got a big (60m x 40m) shed to weld up and once I get the welder into a good spray transfer the tips just burn out. Did 4 in under 5 minutes today so dropped down to dip and they last for hours. So is the problem my settings...
Spray 310 amps 31volts
Dip 270amp 27volts
I'm using 1mm wire and a genuine MB36 with M8 tips but I cant keep it in spray
What sort of settings do you guys run on heavy work?? Do your tips last ok?
Or should i go watercooled as i only need the torch? Got free water (borehole) so i'd just connect to a tap and run it down the drain...
Thanks in advanced
Dip 270amp 27volts
Thanks in advanced
