Noods
- Ipswich
Hi All..
Can you advise pls in advance.. I've a little project where I'm needing to tig 1.2mm steel sheet to a 3mm box steel section..
I know what's likely to happen.. The edge of the 1.2 burning away! Do I try to get a puddle on the thicker piece and then push it to the thin stock.. Are there better ways? I'm sure there are... Should I protect the thin stock with a piece of copper underneath? Would this help? Do I set the amps up for the thin stock or for the heavier piece.. ? Lots of questions.. Any advice would be very very welcome, before, I make a start..
Muchly many thank you's ..
NöODs X
NöODs X
