I'm fitting a new rear inner wheel arch to my BMW E30 325i 2 door saloon, or will be soon. The join where the inner and outer wheel arches meet was originally spot welded. I don't have a spot welder so my options are plug welding or tacking with a mig welder. I don't want rust coming back between the panels so would like to paint the mating surfaces. The problem is that paint will burn away or prevent a good weld. I've tried weld through primer in the past and it's crap.
I did a bit of research and found that body shops tend to use a bonding agent in this area. I can't justify buying the 3m 2 part epoxy and applicator. Would tiger seal be an option? If so what surface preparation should be done? Bare metal or a primer/paint? Any advice would be appreciated.
