I've started practising TIG welding stainless rod. I'm attmepting to join 2.4mm 316L TIG rods. I use a 1.6mm tungsten and run at 12 amps. The welds in the picture are fusion welds and I'm not happy with them. I would prefer to make the joints using filler. I tried with 1.6mm filler but by the time there is enough of a weld pool to melt the wire, the rods I'm trying to join are starting to melt away. When fusion welding it's a bit hit and miss and the threshold between a succesful join and burn through is about a second or two. I set the argon at 8L/min on the regulator but the weld is quite black. Increasing gas flow doesn't seem to make a different. As I've never done TIG/stainless before I have no idea if this is normal.
Would I be better off using a 1mm tungsten and 1mm filler?
Is 316 filler rod different from 316 stainless steel? It was convenient to buy filler rods to start with. Once I master the technique I will probably be buying 3mm 316 rod.
Michael
Michael
